mc controls Posted May 1, 2015 Report Share Posted May 1, 2015 I have new ETM9440-1 3G modem connected to a Vision 1040 for SMS. Modem initializes on PC & PLC OK, I have used Siemens T65 & Cinterion in the "Com Init" block with success. After the "SMS Send" block executes, the first recipient in phone book works and sends OK, but with more than 1 recipient in send function,Modem Status messages returns 8 (Unknown modem reply) The modem uses the Cinterion EU3-3 or PH8-p engines. Need to send up to 6 recipients per SMS message, with more than 64 different messages. Is this in theVvisilogic software or a modem config issue for multiple recipients?? Any help please?? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted May 17, 2015 Report Share Posted May 17, 2015 Hi, PLC recognize modem replays in accordance to selected modem type. ETM9440-1 3G modem is not in supported modems list. There is no issue in VisiLogic, and no issue in modem. As a work around, you can add Ladder code to send multiple SMS one-by-one. I hope this is the fastest and better solution. Quote Link to comment Share on other sites More sharing options...
