Boetje Posted May 27, 2015 Report Share Posted May 27, 2015 Hello My firmware manager of Unilogic cannot find any firmware files He has surging for over 2 hours I already reinstalled Unistream, bud no resold Has Anyone a suggestion, how to solve this problem In need to make a USB stick whit a Upgrade file for my panel Thanks a lot Quote Link to comment Share on other sites More sharing options...
DanT Posted May 28, 2015 Report Share Posted May 28, 2015 Hi; Open a blank project in UniLogic. On the icon line/ribbon starting with Download, go to the right, at the end is UniStream Management This is a dropdown, Choose Firmware manager This will show the firmware required Copy to a DOK Notes: Format the DOK with 4096 sectors ( works for me ) Use a DOK that does not have any software on it, it has to be BLANK to work properly. One other thing: I normally install a Blank program into the PLC BEFORE upgrading ( use your last version of UniLogic to do this) because you will end up having to download an upgraded project into the PLC after the upgrade. Working with a Blank project just makes things easier. Quote Link to comment Share on other sites More sharing options...
Saragani Posted June 1, 2015 Report Share Posted June 1, 2015 Hi, there is a known issue with the Firmware manager. It will not find firmwares (and the application might also crash) if the current user name on the computer has non-English characters. This issue was already addressed and the fix will be avialable on the upcoming UniLogic 1.14 version. If you can't wait for version 1.14, then please contact our support on how to extract the firmware update to your USB Stick. 1 Quote Link to comment Share on other sites More sharing options...
