Blitz Posted January 8, 2011 Report Share Posted January 8, 2011 So far, the solution offered for expansion I/O's on multiple racks is the use of EX-RC1 remote expansion modules. This is great specially if I/O's are distributed over longer distances. However, if only 2 or 3 racks are installed on the same panel, the use of EX-RC1 becomes less practical. So, how about if Unitronics comes up with another local expansion adapter (e.g., say, EX-A2) which would have two (2) RJ-45 connection ports. For example, three expansion I/O racks on the same panel may be connected as follows: 1. Port1 of Rack1 is connected to OPLC. 2. Port2 of Rack1 is connected to Port1 of Rack2. 3. Port2 of Rack2 is connected to Port1 of Rack3. 4. Port2 of Rack3 is terminated. 5. The connecting cable length is less than 1m. This results to a 3-tiered local adapter racks on the same panel. Some benefits of having 1 to 3 local racks are: - simpler to implement - I/O data are more readily accessible -- no separate programming is required as when using RC1. - gives more flexibility on panel mounting (e.g., panel width issues with horizontal module mounting) Thanks. Quote Link to comment Share on other sites More sharing options...
Emil Posted January 11, 2011 Report Share Posted January 11, 2011 Out of doubts this is a good idea. It reised few times here. But the layer of expansion communication doesn't let such option. In fact - as compromise to this request RC1 was designed. Anyway - we are taking this idea in mind and will use any option to implement it. Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted February 15, 2011 External Moderators Report Share Posted February 15, 2011 Well, other solution is to reduce the wight of the expansion modules, maybe a thin expansion module without screws with 32 inputs with the half size of an IO-DI16. Quote Link to comment Share on other sites More sharing options...
Ziwi Posted March 21, 2011 Report Share Posted March 21, 2011 Well, other solution is to reduce the wight of the expansion modules, maybe a thin expansion module without screws with 32 inputs with the half size of an IO-DI16. I second the idea of having narrow I/O modules, as in the cigarette pack size from schneider, beckhoff and others. These are approx 4 x narrower than Uni ones. Our electrician can't figure out why I insist on Unitronics for this reason, and he has a point. When you look at the PCB's inside a Unitronics module it seems relatively easy to stand them up on end? I think this "simple" factor could lose Unitronics sales over other vendors. Quote Link to comment Share on other sites More sharing options...
Daniel L Posted August 13, 2011 Report Share Posted August 13, 2011 I second the idea of having narrow I/O modules, as in the cigarette pack size from schneider, beckhoff and others. These are approx 4 x narrower than Uni ones. Our electrician can't figure out why I insist on Unitronics for this reason, and he has a point. When you look at the PCB's inside a Unitronics module it seems relatively easy to stand them up on end? I think this "simple" factor could lose Unitronics sales over other vendors. I agree. A narrow form factor IO would be easy to do by repackaging the modules on edge and moving the LEDs to be visible. Most panel boxes accommodate the depth easily. Quote Link to comment Share on other sites More sharing options...
John Williams Posted November 17, 2011 Report Share Posted November 17, 2011 I too would like to see the ability of multiple racks that are directly addressed from the OPLC. The current system uses extra operands to mirror the remote IO in the project and also requires more programming of the CANbus communication. Other suppliers have the ability to expand thier systems using addtional racks. It should not be necessary to build installations, like the one pictured, where half the IO are expansion (direct address) and the others are remote (mirrored CANbus) when all modules are in the same enclosure. This is not the first time we have done such a system. Two projects I was involved with required 5 EX-RC1 each, all in the same cabinet. Quote Link to comment Share on other sites More sharing options...
