rich Posted June 11, 2015 Report Share Posted June 11, 2015 I working on a system controlling 10 small VSDs powering water pumps in a water feature. I am using a V350 with 10 Analog outputs to control the VSDs. Could any one recommend how I could achieve varying outputs so as to achieve several pump sequences. Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted June 12, 2015 Report Share Posted June 12, 2015 The drum sequencer is great for this. You can make a bunch of different drums and call them as needed. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted June 15, 2015 MVP 2021 Report Share Posted June 15, 2015 Create a Data Table 10 columns wide and use a pointer to move one row at a time into your drive setpoint registers. Joe T. Quote Link to comment Share on other sites More sharing options...
