DM01 Posted June 15, 2015 Report Share Posted June 15, 2015 hello, i'd like to send rs232 commands with the add-on module MJ20-RS on my jz20-t18. Which function blocks do i need to program for communications with other devices via rs232? greetz, Quote Link to comment Share on other sites More sharing options...
s.pratt Posted June 29, 2015 Report Share Posted June 29, 2015 Hello, In U90, there are no function blocks to program the communications for your unit. You will have to use the special functions to program the RS232 parameters and send information over RS232. You can find example programs in the U90 Help tab for setting up communications. Also, the help files will outline and explain these special functions. Hope this helps. Quote Link to comment Share on other sites More sharing options...
