Kieran B Posted July 11, 2015 Report Share Posted July 11, 2015 Hi As usual I have taken on a job for a customer after the simple question: Can you make this work? So they have supplied me with an encoder (data sheet link below), http://www.beisensors.com/pdfs/H25-optical-absolute-encoder.pdf I was expecting and hoping for a standard ABZ type but instead was confronted with an RS422 type using native binary The code on the side tells me that its 12bits, natural binary, RS-422 serial asynchronous Is it even possible to use this type, I don't even know where to start connecting this one Any help would be appreciated Kieran Quote Link to comment Share on other sites More sharing options...
