wasikhetmaar Posted July 22, 2015 Report Share Posted July 22, 2015 Hello, I have an integer that contains the position of a bit in an array that I would to set to 1. Entering numbers in array for the position is possible, but entering my integer isn't. Unilogic says that the integer is longer then the array length. Is there a possibillity to limit my integer (I know that it isn't longer than my array)? Quote Link to comment Share on other sites More sharing options...
Alexander Posted July 22, 2015 Report Share Posted July 22, 2015 Which integer tag are you using, and how long is your array? Is it possible to post your code so we can review any issues? Quote Link to comment Share on other sites More sharing options...
wasikhetmaar Posted July 22, 2015 Author Report Share Posted July 22, 2015 Hello UniGuru, I'm using the folowing tags: Array Bit[0..8] integer INT16 5 store integer set array[5] works, but when I use set array[integer] it fails. Quote Link to comment Share on other sites More sharing options...
Alexander Posted July 22, 2015 Report Share Posted July 22, 2015 To clarify, you are trying to set the bit in the array using the index value from the integer? For example if the number in the integer is [6] you want to set the eighth bit in an array. So an array of 8 bits would look like 0 0 1 0 0 0 0 0. Is this correct? Quote Link to comment Share on other sites More sharing options...
wasikhetmaar Posted July 22, 2015 Author Report Share Posted July 22, 2015 Yes, however i don't understand the second sentence. I want to set the bit by using the index value. If you got an array bit[0..8] of all zero's and I do: set array[5] the result will be 000010000. after that set array[3] will create 001010000 I would like to do so with a integer. Then I could store the position of the bit that I would like to set in the integer and then set it by doing set array[integer]. Quote Link to comment Share on other sites More sharing options...
Alexander Posted July 22, 2015 Report Share Posted July 22, 2015 Binary is usually read from right to left which is why I gave the example of setting the 6th bit as 0 0 1 0 0 0 0 0 in an 8 bit array. Which function are you currently using within UniLogic? There is not a set array function. There is not a built in function for the operation you are describing but it may be possible to create a UDFB that can replicate this process. Since bit arrays are normally operated from right to left will this work or do you need it to work in the opposite way? Quote Link to comment Share on other sites More sharing options...
wasikhetmaar Posted July 22, 2015 Author Report Share Posted July 22, 2015 BEGIN_RUNG register int RLO1, RLO2; /* BusBar Inited RLOs */ RLO1 = RLO2 = RLO; /* BusBar */ BEGIN_BLOCK /* 1. Direct Contact */ ACC_AND(RLO1, _op_op9F23C19D); /* 2. Set Coil */ SET(RLO1, _op_op08576FC6[12]); /* 3. Reset Coil */ RESET(RLO1, _op_op9F23C19D); END_BLOCK BEGIN_BLOCK /* 4. Find in Array */ FIND_IN_ARRAY(RLO2, _op_op08576FC6, 20, 0, 1, _op_op7DDFD44C); /* 5. Store */ _ERROR_IN_ELEMENT(Error in Element ID = 855f5872-dd58-4b3c-83cb-9ceac16033c3, Message = Error during operand compile ) END_BLOCK /* End Junction */ END_RUNG Can you see what I display here? Don't know another way to display. I just want to store a certain value in an array by entering not a number but an integer between the [ ] Maybe writing a UDFB could be the solution, but is it also possible for multiple arrays? Quote Link to comment Share on other sites More sharing options...
Alexander Posted July 22, 2015 Report Share Posted July 22, 2015 Unfortunately this does not indicate which tags are used. Would it be possible to send your project to support@unitronics.com for further assistance? Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 23, 2015 Report Share Posted July 23, 2015 Hi, The Arrays in UniLogic works in a way that you can give a name to items inside an array. Given that, assume the following situation: Array_Int with Member: Hello // index 0 World // Index 1 Now, the lexer let you access a cell in the array by either: Array_Int[0] or Array_Int[Hello] UniLogic prevents the existance of 2 tags with the same name, on the same scope (You can have 2 local tags, each on a different function with the same name, but having a global tag with that name would create a conflict, because the compilier will not know to which tag you actually refer). Now, consider the following scenario: I also have a tag called Hello.... So if I write Array_Int[Hello], then I want to access index 0, or the index with the value of the Hello Tag? This is one of the resons why we don't allow indirect access to array cells in the way ou have mentioned. About the error you got. The Compiler/Lexer looks for a member called Integer_Tag (or what ever your tag is named), but since it can't find any array member with that name, then it gives you that error (which is in this case, not clear and not accurate). So wait, that means that you can't access an array cell indirectly?? Well, you can, but not in the way you've tried. Try using "Load from Array" for getting a value indirectly from an array, and "Store in Array" for setting a value indirectly to an array. :-) 2 Quote Link to comment Share on other sites More sharing options...
