String entry keyboard
Flex727
The string entry keyboard needs a lot of work. Pressing the CAPS LOCK key does nothing other than turn on a little green light. It appears that one must press the SHIFT key first, then the CAPS LOCK key after to get a caps lock. No keyboard in the world operates this way. If the CAPS LOCK key is not actually on, then the little green light should NOT be lit. Also, pressing the SHIFT key shifts the numeric keys - that's fine, but the CAPS LOCK should NOT shift the numeric keys - just like real computer keyboards.
Frankly, I'd like to see the keyboard default to all caps (i.e. CAPS LOCK ON) with the numeric keys available. In that case, pressing the CAPS LOCK key would allow access to lower case, which are seldom used.
