Gabriel Franco Posted October 20, 2015 Report Share Posted October 20, 2015 Is there a simpler way to set same duration time for all drum other than doing it step by step, like row and column SET/RESET option? Quote Link to comment Share on other sites More sharing options...
Alexander Posted October 23, 2015 Report Share Posted October 23, 2015 All times in the Drum Configuration must be set up manually. One other way to accomplish different times or set them dynamically is to use timers in the logic. When the timer finishes you can have it perform the next step operation. Quote Link to comment Share on other sites More sharing options...
