YOLB Posted December 19, 2015 Report Share Posted December 19, 2015 Hi, I have a question. I'm programming a V1040 with Visilogic, but when I want to configure the hardware, I can not see the IO-IA8 module and expanssion EX-A2X adapter. What I have to do to configure the hardware with this modules? Have a nice day. Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted December 20, 2015 Report Share Posted December 20, 2015 Hello, EX-A2X is an adapter module, no configuration is required. When adding an expansion I/O to VisiLogic HW Configuration the EX-A2X will be "virtually" added to the Configuration. No need to see it in VisiLogic HW Configuration. The module IO-AI8 is presented in VisiLogic > HW Configuration together with I/O-ATC8. I hope it helps. Cheers, Quote Link to comment Share on other sites More sharing options...
