marazass Posted January 18, 2016 Report Share Posted January 18, 2016 hello all, is it possible somehow to clone project from V120 to other same PLC? When I trying to upload project to VisiLogic, I get message "this project cannot be uploaded because: - the option Burn Upload Project was not selected when the project was downloaded, or......" Quote Link to comment Share on other sites More sharing options...
s.pratt Posted January 18, 2016 Report Share Posted January 18, 2016 Hello, It is possible to upload projects from V120 units, then download them to other V120 units; however, this is only possible if the original download was performed in VisiLogic as mentioned (Burn Upload Project). If this option was not chosen upon downloading, then you will not be able to recover the application from the unit. Hope this helps. Quote Link to comment Share on other sites More sharing options...
marazass Posted January 18, 2016 Author Report Share Posted January 18, 2016 bad news.... I have V120 unit with burned I/O port and no original project. The only way to make a project from 0 ? Quote Link to comment Share on other sites More sharing options...
s.pratt Posted January 18, 2016 Report Share Posted January 18, 2016 Unfortunately yes. There is no way to obtain the project from the PLC other than uploading the application from the PLC. There is no SD card option on teh V120 to extract via SD. Quote Link to comment Share on other sites More sharing options...
marazass Posted January 18, 2016 Author Report Share Posted January 18, 2016 even if no good news, thanks for the very prompt replies. Quote Link to comment Share on other sites More sharing options...
