Vinicator Posted January 25, 2016 Report Share Posted January 25, 2016 Hi i was just wondering if there is any way in which SMS messages waiting to be sent out could be erased? I would like to add this function in the event that my modem is jammed up with messages. I couldnt seem to find any way in which i could carry it out. Please Advise. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted January 25, 2016 Report Share Posted January 25, 2016 Hi, Vinicator, After sending SMS to Modem for further processing, there is no easy way to manage SMS queue. Better p[ractice is to check SMS send result and act in accordance. 1)Do not send batch of SMS without checking result. 2)Allocate different memory registers for SMS SEnd status when you send more then 1 SMS. In this case it is simplest to eliminate problem then correct it. I hope this helps. B.R. 1 Quote Link to comment Share on other sites More sharing options...
