ORSO2001 Posted January 26, 2016 Report Share Posted January 26, 2016 Dear All, yesterday I have upgraded the Unilogic from 1_15 to 1_16 without problems. I took a fast look of it and I saw that some "function block" was added at DT and for sure others...I have to try. What happens...When I open my project, created with version 1_15, the new Unilogic highlighted that it was created with an "old" version and asked for upgrade...I choose "YES"...and in the "new" project I see that some, not all, ladder function and HMI function appears as modified...see attached pic...I checked but I don't found variations...what I have to check? In the previous upgrade I don't remember that it happened. Thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted January 26, 2016 Report Share Posted January 26, 2016 An item may appear as modified also then a related (used) tag in that function/screen has been upgraded (A member name was changed, or some members where added/removed). If you are using some system or IO structs, then that might happen. For example, the FTP Server struct was updated... Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted January 26, 2016 Author Report Share Posted January 26, 2016 Dear Saragani, ok. many thanks for your explaination...and let me say: thanks to all of you for your work well done Quote Link to comment Share on other sites More sharing options...
Saragani Posted January 27, 2016 Report Share Posted January 27, 2016 Quote Link to comment Share on other sites More sharing options...
