prebone Posted January 27, 2016 Report Share Posted January 27, 2016 Hi there, got troubbled when I tried to upgrade from UniLogic 1_15 to 1_16. The installer went in loop while uninstalling the old version. So, I uninstalled the old version manually, to clear the way for the new installation. But, all my gain was the error message: "The setup has detected that no version of Unitronics UniLogic is installed. The specified command-line options require that the application be installed to continue. The setup will now terminate." Also tried to install an older version again, but got the same error. Win7 SP1, and then Win10. Same result. Any way to get to change some command-line options here, or what? /Preben Quote Link to comment Share on other sites More sharing options...
Saragani Posted January 28, 2016 Report Share Posted January 28, 2016 How did you uninstall it manually? by Deleting the files in the Program files? 1) Try uninstalling UniLogic from the Control Panel (Add remove programs) 2) Download the attached file, and extract the exe inside it to C:\ 3) Run the command prompt as Administrator 4) Navigate to your C:\ in the command prompt (using CD\ ) 5) Execute the following command in the command prompt: msizap T {83C5EAE0-FB24-4ACD-848A-9286B0DC30C1} (You may want to copy paste it from this thread to the command prompt) 6) Install UniLogic 7) Reboot the PC MsiZap.zip 2 Quote Link to comment Share on other sites More sharing options...
prebone Posted January 28, 2016 Author Report Share Posted January 28, 2016 Thank's SUCCESS!!! This did it! Got installed UniLogic 1_16, and it is running smooth! ;-) It all started as this: Ran the installation-file "UniLogicSetup_1_16_Build_44_WIN7_SP1.exe" After the WelcomeDialog appeared, I unchecked the checkbox-option "keep a copy of the old version" As the installationprogram proceeded with uninstalling the old version, again and again, I canceled that process. So, I uninstalled the old version (1_15) from the control panel, then I removed what was left of Unilogic in the program folder, and so I traced up any listing containing "unilogic" in the registry and deleted it. When I then ran the installation-file of 1_16 again, the story proceeded as mentioned. But now, everything is perfect! Thank's again for the super-fix-file! /Preben Quote Link to comment Share on other sites More sharing options...
Benjamin Boyries Posted October 27, 2016 Report Share Posted October 27, 2016 Hello, I had the same error for installing the UniLogic V1.18 I tried your way and it works perfectly. Thank you so much ! Benjamin Quote Link to comment Share on other sites More sharing options...
Mitchell Halpern Posted September 24, 2021 Report Share Posted September 24, 2021 Hello, I am an IT tech at my company. I have a user with the same issue when trying to update/install Unilogic. I found this thread and went to download that zip file, but it no longer exists. Is there a new version that I can use for my issue? Regards Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 29, 2021 Report Share Posted September 29, 2021 MsiZap.exe Please use this one Quote Link to comment Share on other sites More sharing options...
Tommy Posted December 22, 2022 Report Share Posted December 22, 2022 Hi, Can you send the link again please? It isn't available anymore Thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted December 23, 2022 MVP 2021 Report Share Posted December 23, 2022 Tommy, that link is still working for me. You have to be logged in to get it. cheers, Aus Quote Link to comment Share on other sites More sharing options...
mario81 Posted January 5 Report Share Posted January 5 On 1/28/2016 at 7:34 AM, Saragani said: How did you uninstall it manually? by Deleting the files in the Program files? 1) Try uninstalling UniLogic from the Control Panel (Add remove programs) 2) Download the attached file, and extract the exe inside it to C:\ 3) Run the command prompt as Administrator 4) Navigate to your C:\ in the command prompt (using CD\ ) 5) Execute the following command in the command prompt: msizap T {83C5EAE0-FB24-4ACD-848A-9286B0DC30C1} (You may want to copy paste it from this thread to the command prompt) 6) Install UniLogic 7) Reboot the PC MsiZap.zip 54.64 kB · 78 downloads Thank you Saragani, worked for me. Quote Link to comment Share on other sites More sharing options...
