Moran Posted February 24, 2016 Report Share Posted February 24, 2016 Hi, I have a button on the HMI that doing some actions, I want to press this button from the ladder code, how can i address that button? there is no a link bit like visilogic. Can I address HMI element by using it's name? thanks, Moran Quote Link to comment Share on other sites More sharing options...
s.pratt Posted February 24, 2016 Report Share Posted February 24, 2016 Hello Moran, Are you trying to make the button appear to be pressed via the ladder? If so, you may want to use a binary image variable instead, and link the action tag to the link for the binary image. Then you may address the link in the ladder. Please let me know if this helps. Quote Link to comment Share on other sites More sharing options...
Moran Posted February 25, 2016 Author Report Share Posted February 25, 2016 Hi s.pratt, thanks for your repliy , i think what you suggest is the answer for me...i will check it thank you. Quote Link to comment Share on other sites More sharing options...
Moran Posted February 26, 2016 Author Report Share Posted February 26, 2016 hi, i tried to use a binary image but still does not work as i need, what i am trying to do is to put a button on the HMI and by pressing it i want to operate another button (or a binary image) that has some actions inits action collection but it is not working well... thanks for your help. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted February 26, 2016 Report Share Posted February 26, 2016 How do you currently have this set up? (Actions/Links) Can you attach your example for us to review? Quote Link to comment Share on other sites More sharing options...
Moran Posted February 28, 2016 Author Report Share Posted February 28, 2016 How can i attached a photo? Quote Link to comment Share on other sites More sharing options...
Moran Posted February 29, 2016 Author Report Share Posted February 29, 2016 hi, i attached 2 photos, the first called 1.GIF you can see a button called "Start Simul" that has 1 action (set bit to Start_Simul bit) the second photo called 2.GIF there is a binary image that link to the bit "Start_Simul" and has 2 actions (set bit and increment ) i want to press the Start Simul button and operate the 2 actions in the binary image. now when i pressed the Start Simul button the binary image change the image but the 2 actions dond work, if i press the binary image directly the 2 actions work. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted March 1, 2016 Report Share Posted March 1, 2016 Dear Moran, Please forgive me if I write my opinion in your post; the tags that are shown in the 2.gif (Tpp_on and Tpp_Index) will be "managed" only if button (circular button) will be pressed or clicked (direct action)...if I well understood you want/need that these tags are managed when you press or click the orange square button that already manage the "Start_simul"... this tag will switch the binary image but not the tags linked inside (not direct action). Then you have to remove the tags (Tpp_on and Tpp_Index) from the grid of circular button and insert the same tags in the grid of orange square button. I hope that I have not said stupid things...in case, please, forgive me because I am a newbe. Quote Link to comment Share on other sites More sharing options...
Moran Posted March 1, 2016 Author Report Share Posted March 1, 2016 hi ORSO2001, what you say it's correct, but it is not what i am trying to do... now i have 8 binary images (like the circular button) and for each of them i attaced the 2 actions. and when the operator press one of them the actions shuold be work and this is working but i want to press a button (the orange button) and to activate the 8 binary images automatic (make the 2 actions ) at difference time, first operate the first binary image ,after 10 sec operate the second and so on....but this is not working... Quote Link to comment Share on other sites More sharing options...
s.pratt Posted March 1, 2016 Report Share Posted March 1, 2016 Hello Moran, ORSO2001 is exactly correct. The actions are a touch property of the button, so will only be activated if the button is touched. I would move the two actions from your binary image, and add them to the actions of your Start Simul button, just as ORSO2001 has mentioned above. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted March 1, 2016 Report Share Posted March 1, 2016 hi ORSO2001, what you say it's correct, but it is not what i am trying to do... now i have 8 binary images (like the circular button) and for each of them i attaced the 2 actions. and when the operator press one of them the actions shuold be work and this is working but i want to press a button (the orange button) and to activate the 8 binary images automatic (make the 2 actions ) at difference time, first operate the first binary image ,after 10 sec operate the second and so on....but this is not working... Hi Moran, Ok...but in this case you have to "create" a ladder condition, by timer, contact etc...and insert the "set" or "reset" command inside the orange button. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 1, 2016 MVP 2021 Report Share Posted March 1, 2016 Moran, you need to distinguish between the "Tag: Link" and the "Tag: Touch...". The Tag: Link is what will be changed in your ladder to have your button change in appearance. The Tag: Touch is where you define the actions that will occur when the button is touched. Those actions can include Set or Reset of the Tag: Link. Quote Link to comment Share on other sites More sharing options...
Moran Posted March 3, 2016 Author Report Share Posted March 3, 2016 hello, thank you all for your reply, i had a little misunderstanding about the action list at the button properties. i now understand that this actions take place only when you actually touch the screen. so i moved this actions to the ladder code and now it is working. thank you all again!! Quote Link to comment Share on other sites More sharing options...
