YINGD Posted March 14, 2016 Report Share Posted March 14, 2016 I am working on a Unistream Project that will use an EX-RC1 module with an IO-AI4AO2. Does anybody happen to have a Visilogic example File for this configuration? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 14, 2016 MVP 2021 Report Share Posted March 14, 2016 There is one included with VisiLogic. Go to Help/Examples/Version 900/Project examples/Communications/EX-RC1/EX-RC1 With Analog/EX-RC1 with AI4AO2/EX-RC1 with Digital and AI4AO2.VLP Quote Link to comment Share on other sites More sharing options...
YINGD Posted March 15, 2016 Author Report Share Posted March 15, 2016 Thanks Flex727, I found the example file. I had to modify it to only have the AI4AO2 and then I downloaded it to my EX-RC1. I also did the export to Unilogic and then imported back into visilogic like the tutorial and the help files show and it still doesn't seem to be working for me. I do have a flashing green "Bus COMM" light on the front of the EX-RC1. According to the EX-RC1 Spec sheet, this means that it is in STOP Mode. I connected to the EX-RC1 and tried forcing it to the Run mode using Visilogic (Reset options in the "Communication - PC settings"). and I cannot seem to get the light to stop flashing. How do I fix this? Quote Link to comment Share on other sites More sharing options...
YINGD Posted March 15, 2016 Author Report Share Posted March 15, 2016 I just tried forcing the EX-Rc1 into stop mode and the IO COMM light started flashing so I think I misread the spec sheet for the EX-RC1. The blinking Bus COMM light seems to be telling me that the communication to the OPLC is not established. Does this mean that only the wiring could be the problem or is there some other possibility that could be causing the fault? I should mention that I am using only (1) EX-RC1 and according to the wiring diagram for the a CANBus network, there are (2) resistors at each end of the network. At the moment, I am not using any resistors in my network because I could not figure out where to put them and I was not sure if they are needed when only (1) module is used. Is it possible that the lack of resistors could be causing the problem? For reference, I am getting a solid green light for IO Comm on the EX-RC1 and a the RUN light on the AI4AO2. Quote Link to comment Share on other sites More sharing options...
DerekGodown Posted April 5, 2018 Report Share Posted April 5, 2018 YINGD, I'm having an issue almost exactly like this, did you ever find out what was missing to complete the Bus COMM link? I'm using an ATC8 but the basic failure to connect to the PLC issue is there, would love to hear back from you or anybody else who knows how to complete this step. Quote Link to comment Share on other sites More sharing options...
DanT Posted April 5, 2018 Report Share Posted April 5, 2018 Hi; When using the EX-RC1 with UniStream, DO NOT USE THE VISILOGIC EXAMPLE PROGRAMS !! Down load the UniStream Examples from the UniLogic Download area -- just below the UniLogic download.. There are EX-RC1 Examples related to UniStream there. UniStream uses different registers than Visilogic. Based on my experiences , I have written a sequence of steps to take to use 1 or more EX-RC1 with UniLogic . Yes, there are steps that must be done ( Visilogic is Involved also) in order to do it successfully. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 5, 2018 MVP 2021 Report Share Posted April 5, 2018 And if any wiring method for any type of communication link says to use resistors, do it. Sometimes it will work without them, but they are there for a reason. Generally I put them into the relevant bootlace before crimping. This can be a bit fiddly at times, but works best. cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
YINGD Posted April 6, 2018 Author Report Share Posted April 6, 2018 Sorry DerekGodown, I was unable to get theComm Link to work so I gave up on it. It was an experimental task for me and I did not have a real application so not getting it to work was not a huge problem. I can say that I was trying to use an example program so the example program I was using may have had issues as DanT had mentioned Quote Link to comment Share on other sites More sharing options...
