Hilton Jr. Posted April 3, 2016 Report Share Posted April 3, 2016 Dears: I´m using the V350 in a new project, for measures in 3 coordinates (in milimeters), using encoders, and after finish one measure, the display must be reset, and the results send to one PC. Explaning better, one block will move in one table and 3 arm with encoders will check the 3 dimensions of this block. 2 sensors will check when material is present (start count), and when the material finish the way (send the measure to PC, and reset the coordinates). Like I don´t have or find a good manual to explain how to do the plc/ihm program, please, I´m needing one step by step to do this program. Thank you!!!! Quote Link to comment Share on other sites More sharing options...
