sid Posted April 11, 2016 Report Share Posted April 11, 2016 Hello everyone, I have a PLC (USC-P-B10) with a HMI (USP-070-B10). I want to use them as a master to set attributes singles to a slave gateway. I found this example project: UniStream_070_Ethernet-Ip_Explicit_Scanner.ulpr . Therefore, I tried it with setting the node IP in the Scanner node tag and upload the project. It does not seem working. Is there anything else I need to setup? What I want is just set a single attribute when I press a button. For example, I have a button on the screen, when I press it, set number '1' to 'class 2, instance 3 attribute 4'. I know I can change the class, instance and attribute in the software (EIP set attribute single function). Any help is appreciate. Quote Link to comment Share on other sites More sharing options...
