Meeg Posted April 14, 2016 Report Share Posted April 14, 2016 Hello I am using UniLogic v1.16 Rev 44 If I change the text in the Description field of a STRUCT member/tag, it is not updated in the Global tag where the struct is used. Suggestions on to make it work? Regards Anders Quote Link to comment Share on other sites More sharing options...
Alexander Posted April 15, 2016 Report Share Posted April 15, 2016 Currently the description field is only carried over when the instance of the struct is created. Should you wish to have different descriptions this allows you to edit the descriptions field and then create another instance. Otherwise all tags using the same struct type would have the same description. Should this be an issue please contact support@unitronics.com Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 18, 2016 Report Share Posted April 18, 2016 This is one of the things that were fixed in 1.17 (Coming soon) Quote Link to comment Share on other sites More sharing options...
