Ant3G Posted April 25, 2016 Report Share Posted April 25, 2016 Please tell me what am I doing wrong? Strings that are received on COM port are like this:A016A117A126A121.. How to configure FB to eliminate A and receive other 3 numeric values? I tried all kind of different combinations and nothing is working 100% correctly. Atm settings are configured as stream and number that I get is only last two characters. How should I configure it to get always 3 last characters? Picture of configuration is attached. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Ant3G Posted April 26, 2016 Author Report Share Posted April 26, 2016 Ok, I did it. Removed 'A' character on source and now using numeric, not stream option. Everything is working fine. Can anyone give me example or point me how to make communication JAVA - PLC? What is the easyest way to do custom things with data from PLC on computer programmatically? Quote Link to comment Share on other sites More sharing options...
