ofer.yishai Posted April 26, 2016 Report Share Posted April 26, 2016 Hello, when starting SD Card Explorer I get an error "Corrupted Favorites XML File. Favorites will not be loaded" Lately I upgrade my PC from WIN7 to WIN10 64 bits. I am not sure but I think the program starts normally after the upgrading. nevertheless uninstall and then re-install PC Suite latest version 2.0.59 after deleting the installation folder completely did not help. where is the Favorites XML File location? what is the solution? Thanks in advance for the replies . Ofer Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 27, 2016 Report Share Posted April 27, 2016 Try running the program as Administrator, see if it helps. Quote Link to comment Share on other sites More sharing options...
ofer.yishai Posted May 1, 2016 Author Report Share Posted May 1, 2016 Thanks. it helps for me! Quote Link to comment Share on other sites More sharing options...
