spilleravr Posted May 4, 2016 Report Share Posted May 4, 2016 Hi guys, I need some advice. I want to touch a temperature variable and want a trend (how did the temp change) to pop up on the screen on top of other variables. Is it possible to bring variables/trends infront of anything else? If not, how should I continue to achive this goal? Cheers, T Quote Link to comment Share on other sites More sharing options...
cantcliff Posted May 4, 2016 Report Share Posted May 4, 2016 You typically can't put HMI items in front of other items. I would recommend a screen that the HMI jumps to when you press a button and then use small elements for the other variables. Quote Link to comment Share on other sites More sharing options...
spilleravr Posted May 4, 2016 Author Report Share Posted May 4, 2016 You typically can't put HMI items in front of other items. I would recommend a screen that the HMI jumps to when you press a button and then use small elements for the other variables. Thanks for the reply ! I guess I have ti create separate display then Quote Link to comment Share on other sites More sharing options...
rupeje Posted June 1, 2016 Report Share Posted June 1, 2016 Is there any way to run a trend in the background, so when you first "open" the trend, it is already populated with the historical data? What I'm seeing is that I can "open" a trend, but it only starts logging when it is opened. If you close it to do something else, the history is lost. Quote Link to comment Share on other sites More sharing options...
