Phil Posted February 2, 2011 Report Share Posted February 2, 2011 I was looking at the help file for the 'Load Timer Bit' function. Every value in the example is 5. If someone is confused about which value the example is refering to then having the same value for all options doesn't help the problem. TA5, D#5, MB5 & preset=5. The text is 'Since 5 is the offset in the timer vector, the bit value of TA5 is loaded into MB5'. That's a lot of 5's Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted February 2, 2011 Report Share Posted February 2, 2011 Hi Phil, You are entirely correct. I'll remember this, and if time allows, will edit that topic. Thanks for taking the time to send that in. Quote Link to comment Share on other sites More sharing options...
Phil Posted February 2, 2011 Author Report Share Posted February 2, 2011 I was looking at the help file for the 'Load Timer Bit' function. Every value in the example is 5. If someone is confused about which value the example is refering to then having the same value for all options doesn't help the problem. TA5, D#5, MB5 & preset=5. The text is 'Since 5 is the offset in the timer vector, the bit value of TA5 is loaded into MB5'. That's a lot of 5's Quote Link to comment Share on other sites More sharing options...
