Abomination1 Posted June 2, 2016 Report Share Posted June 2, 2016 Hello; do everyone know, can on V350 someone run this - > http://www.murrelektronik.com/fileadmin/USERDATA/Downloads/English/Manuals/55364_hdb_e_16.pdf This is Profibus 16x DI module. What do i need and how can i configure it? Can i run it, or is need to change the protocol? Best Regards Quote Link to comment Share on other sites More sharing options...
Henny Posted June 2, 2016 Report Share Posted June 2, 2016 Hello This is not possible because Unitronics plc can only act as profibus slave and the module you want to connect is also a profibus slave. I see a Unitronics plc with profibus card as a intelligent remote i/o device including Hmi that you connect to a profibus master. For Unitronics plc you have to look for modbus rtu or tcp remote i/o, or the i/o modules offered by Unitronics. Kind regards Henny Quote Link to comment Share on other sites More sharing options...
Henny Posted June 2, 2016 Report Share Posted June 2, 2016 Hello @For Unitronics plc you have to look for modbus rtu or tcp remote i/o, or the i/o modules offered by Unitronics. Canbus I/O can also be used by Unitronics. Noticed that Murr also offers Can open protocol so I think you would need this one then. http://shop.murrelektronik.com/en/I-O-Systems/Impact67/IMPACT67-COMPACT-MODULE-PLASTIC-55075.html I don,t have experience with Canbus but at least I know that for a V350 you have to order a V100-17-can module. Kind regards Henny Quote Link to comment Share on other sites More sharing options...
