DanT Posted January 19, 2018 Report Share Posted January 19, 2018 Hi Mousemania; Windows 10? Latest Updates? -- Win 10 is a real pain! Uninstall 1.22.13 Get Into Control Panel - Programs and Uninstall the SQL Server Shut down the computer. and Restart. ( Sometimes RAM remembers what is supposed to be erased ) Install 1.22.13 ( This will cause an new SQL Install to be done ) (When doing and uninstall of a current UniLogic, it does not uninstall the SQL Server. Uninstall SQL Server forces the New UniLogic install to install it again, Subtle changes can cause headaches)) Been there , done that ! Dant Quote Link to comment Share on other sites More sharing options...
Dragan Birimac Posted January 26, 2018 Report Share Posted January 26, 2018 I had the same problem and the diagnostic tool fix it for me. Unilogic version is 1.22.13 and win 10x64. Quote Link to comment Share on other sites More sharing options...
Jan N Posted January 31, 2018 Report Share Posted January 31, 2018 Well... It worked for me. And I had the same problem at first, that the fix button didn't do anything. I waited a bit and then it turned out the button had done what it was supposed to do. Great! Jan Quote Link to comment Share on other sites More sharing options...
JJtellez Posted February 5, 2018 Report Share Posted February 5, 2018 Tenia el mismo problema estoy en windows 10 version 1709. Ejecute "Unilogic diagnoctics.exe" di click en "Fix" y ahora ya inicio, muchas gracias!! Quote Link to comment Share on other sites More sharing options...
ruan@silvis.co.za Posted February 26, 2018 Report Share Posted February 26, 2018 Hi, Also fixed my problem thank you. The .rar file will only download after you have registered a profile. Thnx Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 27, 2018 Report Share Posted February 27, 2018 8 hours ago, AlexUT said: Hi, When starting UniLogic and it is stuck on "Loading Components", do next to delete and re-create SQL Database instance: Stop Unitronics Notifier (Unitronics.Notifier.exe) from Task Manager. Start Windows cmd Type: sqllocaldb stop UniLogic Type: sqllocaldb delete UniLogic Type: sqllocaldb create UniLogic In windows explorer, write: %ProgramData%\Unitronics\UniLogic\Temp Enter the folder with the username. Delete all the files there (mdf and ldf) Start UniLogic and try to open a project. If this does not helps, contact Unitronics Support at support@unitronics .com to schedule remote session. B.R. It is best to avoid doing these steps manually, since the Diagnostics tool does them automatically if it detects a problem with the instance. Furthermore, problems will happen if the cmd is not started as Administrator, and problems may happen if the UniLogic instance is created on a different version of SQL Server. Meaning, the actual command should be: sqllocaldb create UniLogic 11.0 If a newer version version of SQL Server local DB is installed then running "sqllocaldb create UniLogic" will create the instance on the new version. This means that any project that is saved with this version will not open on computers with the UniLogic instance running on SQL Server 2012 (which is the version we use). Quote Link to comment Share on other sites More sharing options...
thethinkman Posted March 19, 2018 Report Share Posted March 19, 2018 I am on 1.23 Rev 25 and I had the same issue described above and it was fixed by the diagnose application in the RAR file. I suggest that this fix is automatically applied in the future. Quote Link to comment Share on other sites More sharing options...
VictorN Posted April 23, 2018 Report Share Posted April 23, 2018 Hello, The link with the rar file seems to work but no more available, could you please resend it? Regards, Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 23, 2018 Report Share Posted April 23, 2018 I just checked, the link works fine: http://forum.unitronics.com/applications/core/interface/file/attachment.php?id=2347 Quote Link to comment Share on other sites More sharing options...
Yoda Posted April 27, 2018 Report Share Posted April 27, 2018 On 1/2/2018 at 11:51 PM, Saragani said: Download the attached Rar file, and extract the files to UniLogic installation directory. This means that the "UniLogic Diagnostics.exe" (and all the other files) must be placed in the same directory where "Unitronics.Shell.UI.exe" is located (usually at: "C:\Program Files (x86)\Unitronics\UniLogic\") After you've extracted the files, run "UniLogic Diagnostics.exe" and click on Diagnose. Most chances that it will show "SQL Instance" as one that has problems. In case it find problems, the "Fix" button will become enabled. Click on Fix, and the program will attempt to fix the problem, and then it will re-diagnose the problems to confirm that they are fixed. Please tell me what problems it found . Also tell me if it managed to fix the problem that you're experiencing with UniLogic (that it is stuck in loading components). Thanks. UniLogic Diagnostics.rar This was very helpful. Simple and solved the SQL Instance issue. Thanks! Quote Link to comment Share on other sites More sharing options...
_MELLON_ Posted May 12, 2018 Report Share Posted May 12, 2018 Hello i have same problem ,is someone solve this issue ? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted May 12, 2018 MVP 2021 Report Share Posted May 12, 2018 If you have the "same" problem, have you tried the solutions listed here in the topic? cheers, Aus Quote Link to comment Share on other sites More sharing options...
Dumbfitter Posted May 13, 2018 Report Share Posted May 13, 2018 I'm having the same problem. I tried downloading the Unilogicdiagnostics.rar. All i get is a Rar file that will not extract and does not have an .exe file in it. What am i doing wrong? I tried reinstalling Unilogic ,running as admin, and deleting the tmp files. Thanks for everyone's help. Ray Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 13, 2018 MVP 2021 Report Share Posted May 13, 2018 I clicked on the link above for UniLogicDiagnostics.rar and there are definitely files in it. I've always used Winzip to extract compressed files - what are you using? Joe T. Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 13, 2018 Report Share Posted May 13, 2018 I'm not sure WinZip can extract rar files, but WinRar and 7Zip can. Quote Link to comment Share on other sites More sharing options...
Dumbfitter Posted May 14, 2018 Report Share Posted May 14, 2018 I don't even get an option to extract or unzip it . attached is what i get Quote Link to comment Share on other sites More sharing options...
Dumbfitter Posted May 14, 2018 Report Share Posted May 14, 2018 Thanks Joe and Saragani for all your help. Did not know what an rar file was and did not know about WinRAR. As my name implies I'm just a Dumbfitter lol. I did get it to work . Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 14, 2018 MVP 2021 Report Share Posted May 14, 2018 I should have explained what a .rar file is. For future reference, a file with a .rar extension is a compressed file, typically used by hardcore programmers to toss Unix (or Linux) filesets around. It a more efficient compression algorithm but not seen as often on the web as a .zip file. As shown by your screenshots, Windows acts dumb when it sees one. Microsoft knows damn well what they are but I have a feeling because they are so popular with the Linux community that there was a conscious decision made by the Windows development team to not include in the default supported file extensions. Keep up your efforts! Joe T. Quote Link to comment Share on other sites More sharing options...
Alex Posted June 16, 2018 Report Share Posted June 16, 2018 I followed the guide. the software works. Thanks to all Quote Link to comment Share on other sites More sharing options...
SATSam16 Posted June 20, 2018 Report Share Posted June 20, 2018 (edited) Is there a manual fix for this? Solved: http://support.unitronics.com/index.php?/selfhelp/view-article/UniLogic-is-stuck-on-Splash-screen-loading-components Edited June 20, 2018 by SATSam16 found soloution Quote Link to comment Share on other sites More sharing options...
Saragani Posted June 20, 2018 Report Share Posted June 20, 2018 The UniLogic Diagnostics should solve the problem. There is no need for a manual. Just run the tool and click on the Diagnose button. If it finds a problem, then the Fix button will become enabled, and clicking on it should solve the problem. I would not recommend following the instructions written at the link you've posted, since they are incorrect. The create command is missing 11.0 at the end, meaning, the command should be: sqllocaldb create UniLogic 11.0 I'm wondering if you now have UniLogic running with SQL Server instance in the wrong server version (Which will make your projects un-openable on other user's computers which uses the correct SQL Server version). To check the SQL Server version of the UniLogic instasnce, type in the command line: sqllocaldb i unilogic If you see under the version 11.0.23180 or any number that starts with 11.0, then it's OK, but if you see a number that starts with 12.0, 13.0 or any other number, then this is not good. Option 4, running MSIZap and then running UniLogic would not solve a thing, but just create more damage than good. Quote Link to comment Share on other sites More sharing options...
Ebenezer Posted November 17, 2018 Report Share Posted November 17, 2018 It worked for me! Quote Link to comment Share on other sites More sharing options...
Kludge Posted June 15, 2020 Report Share Posted June 15, 2020 Works for me as well. SQL Instance failed Quote Link to comment Share on other sites More sharing options...
Annatooli Posted July 17, 2020 Report Share Posted July 17, 2020 On 5/14/2018 at 3:49 AM, Joe Tauser said: I should have explained what a .rar file is. For future reference, a file with a .rar extension is a compressed file, typically used by hardcore programmers to toss Unix (or Linux) filesets around. It a more efficient compression algorithm but not seen as often on the web as a .zip file. As shown by your screenshots, Windows acts dumb when it sees one. Microsoft knows damn well what they are but I have a feeling because they are so popular with the Linux community that there was a conscious decision made by the Windows development team to not include in the default supported file extensions. Keep up your efforts! Joe T. It is old post but .rar files are actually from DOS and BBS era and they are still popular in file sharing and archiving. Microsoft wont include support because rar format is closed source when zip format is very much open source. So they wont have to pay some 3rd party. Rar file format compared with zip format has been very stable over the years. In late 90s and beginning of 2000s there were some "Special" versions from zip what may still be incompatible. But you can read all rar files even when they are from 90s. Common format from Linux (unix) is .tar and its compressed extensions (.tar.z / .tar.gz) it stores unix specific file permissions also into archive. Today it is common to use zip and rar in linux when there is no need to keep file permissions. For Linux there is also 7z available. Anatoly Quote Link to comment Share on other sites More sharing options...
Brans Posted July 22, 2020 Report Share Posted July 22, 2020 On 1/3/2018 at 5:51 AM, Saragani said: Download the attached Rar file, and extract the files to UniLogic installation directory. This means that the "UniLogic Diagnostics.exe" (and all the other files) must be placed in the same directory where "Unitronics.Shell.UI.exe" is located (usually at: "C:\Program Files (x86)\Unitronics\UniLogic\") After you've extracted the files, run "UniLogic Diagnostics.exe" and click on Diagnose. Most chances that it will show "SQL Instance" as one that has problems. In case it find problems, the "Fix" button will become enabled. Click on Fix, and the program will attempt to fix the problem, and then it will re-diagnose the problems to confirm that they are fixed. Please tell me what problems it found . Also tell me if it managed to fix the problem that you're experiencing with UniLogic (that it is stuck in loading components). Thanks. UniLogic Diagnostics.rar It was helpful! Thank you! Quote Link to comment Share on other sites More sharing options...
