Unilogic Alarm Timers
In the Unilogic built in alarms, you can select an 'on delay' or 'off delay' timer. These are fixed values, hardcoded into the programme.
It would be nice to be able to link these to timer structs so that you can adjust the alarm time from the HMI in a running programme.
I am aware that you could just write ladder code that uses the timer struct, and then call a bit to trigger the alarm, but it would be much nicer to implement as above
  • 3 weeks later...
  • 4 months later...
