Joesteva Posted August 15, 2016 Report Share Posted August 15, 2016 Greettings, is there a way to export the csv file including the date in the file name? Currently I have the name "Refinacion" as the exported file name, I think it is overwritting this file every time it exports. Quote Link to comment Share on other sites More sharing options...
Alexander Posted August 16, 2016 Report Share Posted August 16, 2016 Can you clarify what you mean by export the file? Do you wish to send it out using the FTP server? When creating the CSV file from the Data Table using the Store DTI to File block you have the option to append the file in the Input parameter E. By default this value is 0, but if you change it to a 1 it will append the data without needing to change the file name. Quote Link to comment Share on other sites More sharing options...
