schafbo Posted August 16, 2016 Report Share Posted August 16, 2016 I sure hope not. I was setting up the High Speed Output example with a V130-TRA33 and accidently set SB 300 (Reset PLC) to a coil that is always ON. I uploaded to the PLC and when running the programming it continuously resets itself. I've tried to upload new programs and stop/reset the PLC in the Communications tab, but it keeps giving me the "Connections could not be established due to..." error like the PLC isn't plugged in. My port/baud settings are correct, I have another V130 that I use and can upload to. Has anyone encountered this? Quote Link to comment Share on other sites More sharing options...
dan Posted August 16, 2016 Report Share Posted August 16, 2016 Hi Schafbo, You can place the controller into OS stop upon power up. This will stop the PLC from running the program. From there, you can can load a new program. Power-up modes are outlined in the help file. Hope this helps! Dan Quote Link to comment Share on other sites More sharing options...
schafbo Posted August 16, 2016 Author Report Share Posted August 16, 2016 Great! Thanks Quote Link to comment Share on other sites More sharing options...
