Carter Posted September 7, 2016 Report Share Posted September 7, 2016 Hi there! I'm using UDFBs many times in my program, but today I need to create an UDFB that allow or not allow to continue the ladder depending on the result inside the block. Using clear terms : I want an UDFB working as a Compare Block. You chose some "In Tag", and then the block compare it (using the way you ask it to) and allow power flows or not. Can we currently make it? Of course, today, I can make an UDFB with a bit as an "Out Tag", and use this bit with a direct contact. Just asking Thank you. Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 11, 2016 Report Share Posted September 11, 2016 Currently, it is not possible to affect the RLO. Quote Link to comment Share on other sites More sharing options...
