ofer.yishai Posted September 21, 2016 Report Share Posted September 21, 2016 Dear all, I am using different data tables in a project, including saving and loading TDI from SD card. Some of the tables are "system" oriented like settings, and some tables are "user" oriented like programs and recipes. User should select a file by using HMI element: File selector browser . For now ALL DTI files are kept in the DT folder and selection is problematic. I need to separate each kind in a different subfolder, so the selection will be user friendly. The "Store DTI to a file" and "Store DTI to a file" ladder blocks is not giving the option for different sub directories , that would helped if exist. File selector browser is not supporting sub folders as well. Can I use differents folder path as part of the file name string? or any other way to manage subfolders? In addition, "Copy/Move file" and ladder elements, don't have the option to copy or move within SD card folders, but only to/from DOK. It would have helpful if possible to arrange the files by type of functions by ladder. any ideas? Any help? 2 Quote Link to comment Share on other sites More sharing options...
Interroga Posted December 2, 2017 Report Share Posted December 2, 2017 any answer to the question? Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 3, 2017 Report Share Posted December 3, 2017 This feature does not exist. Quote Link to comment Share on other sites More sharing options...
