Problem to connect V280 to my lap
wassim
Hello Guys,
I am facing Problem to connect  a V280 to my laptop, we check all the setings,  we even change the usb to serial cable,  we change the also the device with an other v280, we still unable to connect
the  the OS version on the PLC is V5.04 (B13)
on the Laptop we have Visilogic  version 9.8.31, when we try to connect it shows the following
Any one who can assist or knows what could be the problem?
Hi Wassim,
I see no image in your post after "shows the following", so I can only add to what Flex has said, and that is to make sure that you have matching baud rates in device manager and Visilogic, normally 57600.  I have had instances of no connection when the setting in device manager is not the same.
Other than that, perhaps have a good read of all the ideas in this other post, to follow up what Flex has said about drivers:
cheers,
Aus
