wapcs Posted January 22, 2017 Report Share Posted January 22, 2017 Can someone explain the format that the IP address is displayed in the Modbus IP communications status bit and how I can display it as a usual IP address like: 192.168.1.201 Cheers Quote Link to comment Share on other sites More sharing options...
Ofir Posted February 5, 2017 Report Share Posted February 5, 2017 Hi, As you can see the IP address is formatted to UINT32. First of all in online mode you can select in the grid the format IP in order to see it as IP address. If you wish to display it on the HMI , you can use the ladder element in Strings menu - I"P to String" 1 Quote Link to comment Share on other sites More sharing options...
