LJA Posted January 24, 2017 Report Share Posted January 24, 2017 Hi, trying to upload a project from a Vision 120 PLC, the upload option has been disabled after entering wrong passwords several times. Is there any way to re-enable the upload option? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted January 24, 2017 MVP 2021 Report Share Posted January 24, 2017 The Help says you get nine tries, and then if you reset the PLC you can try again. Did you cycle power on the V120? If that doesn't work, go into Information Mode and reset it from there. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
LJA Posted January 24, 2017 Author Report Share Posted January 24, 2017 Thank you, Joe. Yersterday I couldn´t power cycle the V120 because the machine was being used for production. Today I power cycled it and then the upload option was re enabled. Quote Link to comment Share on other sites More sharing options...
