Jamie123 Posted February 9, 2017 Report Share Posted February 9, 2017 Hello, I have a very simple program running on a Samba. I have been asked to include some data capture with an SD card so I have bought some V350 to replace the samba's. Although the program is simple it is quite long. Is it possible to transfer the ladder logic from the Samba to the V350 without having to rewrite it? Thanks in advance for your replies! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 9, 2017 MVP 2021 Report Share Posted February 9, 2017 Sure, just change the PLC in the HW Configuration from Samba to V350 and select the appropriate I/O module. It will throw up a warning about deleting I/O, but ignore that. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 9, 2017 MVP 2021 Report Share Posted February 9, 2017 While this will work when going from a Samba to a V350, it won't always work (for instance, when going from a color to a monochrome HMI). In that case one would need to export each subroutine and import each one into a new project with the correct PLC model selected. Quote Link to comment Share on other sites More sharing options...
Jamie123 Posted February 9, 2017 Author Report Share Posted February 9, 2017 Thanks Flex. I will try importing the subrountines Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 9, 2017 MVP 2021 Report Share Posted February 9, 2017 Jamie123, in your situation you do not need to do export/import - just change the HW Configuration directly. Quote Link to comment Share on other sites More sharing options...
