caddyroyalty Posted April 18, 2017 Report Share Posted April 18, 2017 Looking for help getting my Samba SM70-J-TA22 to read my MKS 925 micropirani vacuum gauge on the 0-10VDC analog input. I have ML0 as my Analog IN and I'm reading values of 860 @ 1 volt and 1500 @ 9 volts. I need to linearize those values to 1E-5 and 1E3 respectively(chart below). Its a logarithmic scale so I'm not sure how to approach this. I know I need a MF as the pressure values have a decimal. Any guidance would be huge. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 18, 2017 MVP 2021 Report Share Posted April 18, 2017 You've probably already deduced that a regular linear block can't handle this. You're going to have to go into floating point land. Convert ML 0 into a float an look at the functions available under Math->Float. To see how to convert it, search "float" in the Help and choose Float:Convert. Read the other Float topics while you're in there. Here's a page I found that may have the formula you need: http://stackoverflow.com/questions/19472747/convert-linear-scale-to-logarithmic Google is your friend if you need more insight on the math. It's been 30 years since I exercised the top buttons on my calculator. Have a go at it and post what code you come up with if you need more help. Joe T. Quote Link to comment Share on other sites More sharing options...
