Read values from Thermocouple J type in Samba 4.3"
Hello, I am new in all of this PLC field but I want to start with small projects in order to get some experience and then moving on bigger projects.
I want to put a graph in my HMI (I actually did it a  Variable thermometer Graph MI 12) and see the real temperature value over the graph. According to the Analog Input Wiring, I know that my input (9) AN0 and input (10) AN1 are the inputs.  First question: When I start to wire up. Do I just put a wire in AN0 and the other in AN1???? or should be connecting in parallel with V
+ one side and the other side with 0 -  references?????
And I know that I have to configure this inputs in my HW configuration. in Analog input I put:         No.     Type           Filter         Mode          Op       Addr         Description
        0        0-10V        No filter                          MI         4                Thermocouple wire +
        1        0-10 V      No filter                           MI         5                Thermocouple wire -
        Can you guys check if this configuration is Ok? I appreciate the help!!!! I am not sure if I have to        link this with MI 4 or MI 5 with the thermometer graph above???
The last question is Do I have to Linearization in my ladder in order to scale values?   if Yes, which variable Do I have to attach the linearization?????
Thanks a lot
sorry for mistakes my English is not my first language.
What model SAMBA  are you using.  The   -T20 and  -R20 models do not support Thermocouples.
Thermocouples produce very small voltages in relation to the temperature being measured. The 0-10V Analog inputs ( 10 Bit )
are  not fine enough to read the millivolts generated.
Thermocouples are supported on the -RA22  and -TA22  Models.   The Installation Sheet  describes the wiring for the various types.
In the  -RA22 and  -TA22  thermocouple inputs is already  converted and the value  is stored as    xxx.x  degrees  C  or F
The Samba is non-expandable so it is not possible to add the required thermocouple input(s) to the unit you have.   As Dan stated you'd have to look at the -RA22 or -TA22 models.
or you'd need an external module to convert the thermocouple input to a 4-20 or 0-10V signal that the PLC can accept.   Phoenix Contact or Weidmuller are two companies which have this type of module.
  • Upvote 1
