Andrew Fehr Posted July 23, 2017 Report Share Posted July 23, 2017 I have a V700 coupled with a LC1 scale module. The unit is doing a control of the filling of bags using a 2 speed fill cycle. The problem I am having is the unit has a light vibration and so it does not stop the final fill uniformly. It seems that the bouncing around is causing the gate to close early or late making the weighs either high or low. Is there a way to smooth out the vibrations without making the settling time so high that the updates are so slow? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 23, 2017 MVP 2021 Report Share Posted July 23, 2017 There is a Filter function available to help smooth out this type of variation, but it seems to me that, fundamentally, filtering data necessarily causes delay. You may have to experiment and stop the filling just short of the required weight. You can also try filling more slowly as you approach the weight limit. Quote Link to comment Share on other sites More sharing options...
Andrew Fehr Posted July 23, 2017 Author Report Share Posted July 23, 2017 I am using the filter function. The Settling time is all the way up to 50 and the Active band at 100 and that is the trouble. The filling already is very slow at the end. that is the reason for the 2 speed fill on the cycle. Without the filling equipment running the settling time can be set down to 15 and the Active band at 30 and the Motion band at 10 and all is calm and settled. But as soon as the thing is turned on causing a slight vibe the display goes wild and the motion is on constantly until the settings are increased. The filtering only slows the reaction time and that causes the uneven cutoff. Is there a way to filter out the high and lows rather that extending the response time? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 23, 2017 MVP 2021 Report Share Posted July 23, 2017 The "Discard Values" parameter does exactly that. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 23, 2017 MVP 2021 Report Share Posted July 23, 2017 FYI: I'm referring to the Filter Function Block that is independent of the Load Cell module. Quote Link to comment Share on other sites More sharing options...
