Adamkse Posted August 1, 2017 Report Share Posted August 1, 2017 Hi, What I want to do set and on and off time and date (which are on different dates) but can only get it to work with the time, not the date. I can get it to work using the "From Hour" and "To Hour" tags but I cant get it to work with the "Month" or "Day of the "Month" tags. I'm not sure of the format, I have been trying to write to them from a RTC Date variable using the array functions and a Date input from the HMI which seems to be working but the "Schedule" function doesn't seem to use the information. I have "2017" written to the "From Year" and "To Year". Any help would be great. Adam Quote Link to comment Share on other sites More sharing options...
Adamkse Posted August 6, 2017 Author Report Share Posted August 6, 2017 Nobody done this before? I also added "Day of the Week" and still cant get it to work Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 6, 2017 Report Share Posted August 6, 2017 It is working for me. I've set From and To year to be 2017, and I've set 1 on the correct month (You can set 1 for several months and Days. It is a boolean map which returns true if nothing is set, or when something is set and it matches the day/month). Quote Link to comment Share on other sites More sharing options...
Adamkse Posted August 8, 2017 Author Report Share Posted August 8, 2017 On 06/08/2017 at 3:19 PM, Saragani said: It is working for me. I've set From and To year to be 2017, and I've set 1 on the correct month (You can set 1 for several months and Days. It is a boolean map which returns true if nothing is set, or when something is set and it matches the day/month). Thanks for the reply. That is what I have I think. Can I upload something to show you what I have? Or can you send me the working example so I can see what going wrong? Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 8, 2017 Report Share Posted August 8, 2017 I'm not at work, and I'll be off until mid of August. You can send the project to the support by email: support@unitronics.com , and they will forward it to the r&d. Quote Link to comment Share on other sites More sharing options...
Adamkse Posted August 9, 2017 Author Report Share Posted August 9, 2017 Ok, I will do that. Thanks. Quote Link to comment Share on other sites More sharing options...
