oobretenov Posted September 28, 2017 Report Share Posted September 28, 2017 Hi, I have a project (HMI USP-070-B10) with several users and groups. Using 3 access levels into the screen controls. I have a client who would like to have full access without login every time when power on the HMI. Is it possible to make something like auto login or to make default user with full access? Thank you in advance, Ognyan Obretenov Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 28, 2017 Report Share Posted September 28, 2017 No, because it doesn't make sense. The whole User Access Control feature is for security and protecting specific pages / elements from being seen or activated by unauthorized personnel. If by resetting the PLC you gain a full access, then the whole feature becomes useless. Quote Link to comment Share on other sites More sharing options...
oobretenov Posted October 5, 2017 Author Report Share Posted October 5, 2017 Thank you. Can you advice me : Is there any easy way to redesign/change the project to remove/disable the UserAccessControl ? I need the same project but when I install on one device to have UserAccessControl and next time when install on another device without UserAccessControl Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 6, 2017 Report Share Posted October 6, 2017 You can disable the UAC. Just go the User Access Control main tree note, hover the User Access control button on the "document"/ pane that was opened, and click on the red x. Then save that project as a different version (so you will have 2 versions) Quote Link to comment Share on other sites More sharing options...
oobretenov Posted October 10, 2017 Author Report Share Posted October 10, 2017 Thank you I will try Quote Link to comment Share on other sites More sharing options...
