ofer.yishai Posted October 29, 2017 Report Share Posted October 29, 2017 Hi, After successful installation of Visilogic V9.8.65 the program crash when I try to open any previous application . The crash just when navigating to a folder containing *VLP files even before selection or even view of any file. In addition the installation influence windows explorer too. when trying to open any folder with *vlp files windows explorer crash, and restart automatically. Same issue with V9.8.31 Only after roiling back to by previous V9.8.22 AND using Version Swapper to register that version, i can open Visilogic, any application, and use Windows explorer normally. I use Windows 10 Pro with administrator rights. anybody experience that too? Any suggestions or cure? Thanks everyone! Ofer Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted October 29, 2017 MVP 2021 Report Share Posted October 29, 2017 Hi Ofer, have a look at this post: Try the complete uninstall, do the careful registry cleanout with CC etc and try again. If you can, do a quick partition copy to get you back to your exact starting point if necessary, rather than a restore point etc. See how you go. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Flarc Posted June 9, 2021 Report Share Posted June 9, 2021 On 10/29/2017 at 9:47 PM, ofer.yishai said: Hi, After successful installation of Visilogic V9.8.65 the program crash when I try to open any previous application . The crash just when navigating to a folder containing *VLP files even before selection or even view of any file. In addition the installation influence windows explorer too. when trying to open any folder with *vlp files windows explorer crash, and restart automatically. Same issue with V9.8.31 Only after roiling back to by previous V9.8.22 AND using Version Swapper to register that version, i can open Visilogic, any application, and use Windows explorer normally. I use Windows 10 Pro with administrator rights. anybody experience that too? Any suggestions or cure? Thanks everyone! Ofer Hi, I had got the same problem, I uninstal visilogic with revoUninstaller (clean folders and register) Tweaking windows repair help to. But, for crash of visilogic when you try to open .vlp from visilogic, I do this : We use Visilogic on a NON admin session for basic security. I have find the solution, but if you use admin session, it would be easier. Start → search → redegit → go to HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.vlp\OpenWithList The value are : (default) REG_SZ (non defined) a REG_SZ VisiLogic.exe MRUList REG_SZ a and Start → search → redegit → open with admin → HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.vlp\OpenWithList(default) REG_SZ (non defined) delete others values For both : OpenWithProgids (default) REG_SZ (non defined) .vlp REG_NONE (binary...) Delete the orthers folders if the exists (like "userchoice") Restart Have a good day ;-) Quote Link to comment Share on other sites More sharing options...
