ARIEL Posted November 6, 2017 Report Share Posted November 6, 2017 WE HAVE AN O.P.L.C. Unitronics M91-2-T38 WITH AN IFM RO3500 INCREMENTAL ENCODER IN THE ENCODER SHAFT INPUT. THE ENCODER HAS A HTL FACTORY OUTPUT (50 mA), 24 Vcc POWER SUPPLY, BUT WE CAN NOT MAKE THAT IT FUNCTION, IT SENDS 1 PULSE FOR REVOLUTION, PROGRAMMED TO 1024 PPR...THE MAXIMUM ESTIMATED COUNTING FREQUENCY IS 1.2 KHZ CAN THIS ENCODER USED AT THE ENCODER SHAFT INPUT?, IS IT AN ENCODER CONFIGURATION PROBLEM?, HOW THE INPUT HAVE TO BE CONNECTED AND PROGRAMED?. Quote Link to comment Share on other sites More sharing options...
Cam Posted November 6, 2017 Report Share Posted November 6, 2017 Take a look at the following you may require some extra diodes to make it function. https://www.posital.com/en/products/communication-interface/incremental/incremental-encoders.php Quote Link to comment Share on other sites More sharing options...
