ORSO2001 Posted December 4, 2017 Report Share Posted December 4, 2017 Dear all, I just update the PLC at version 1.22.13; also I update a project that I wrote with the version 1.19.xx; in this project I have enabled the UAC and insert some users with different levels..also I included a "service" user that has full access...when I try to upload the project I have an error "the password for UniApps Administrator could not be changed" and the download don't works. I tried to set the "service" user as "super group" but was the same. what I'm doing wrong? Quote Link to comment Share on other sites More sharing options...
EduMarg Posted December 5, 2017 Report Share Posted December 5, 2017 Dear ORSO2001, I tried to replicate this issue with an application build on 1.19 with UAC with a user set as supper group. I open the application with latest UniLogic 1.22.13 and download it to a UniStream with latest firmware 1.22.9 In my case it worked OK and had no issues downloading the application to the UniStream. I got no error message. Can you please try downloading an empty application to the UniStream. After this please try to download your application. If this does not work, please send the application to support@unitronics.com for review. Also, please send a screenshot of the error message you get. Thanks. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted December 5, 2017 Author Report Share Posted December 5, 2017 Dear EduMarg, I done what you seggested...upload an empty project (and it works) I tried again to upload the project with the UAC and I have had the same problem. ASAP I send the project to your support (with screenshot). thanks. Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 5, 2017 Report Share Posted December 5, 2017 What you describe might be a problem with this specific PLC (problem with one of the files). Have you tried to unplug the PLC from the power and then re-plug it? Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted December 5, 2017 Author Report Share Posted December 5, 2017 dear Saragani, sorry...what you mean for unplug and re-plug?...are you talking about during update?...I turned ON my PLC then update without any power missing and without any "error" message...only at the end I have had the highlight that the program uploaded was not "compatible" with the actual version (as usual)...then I tried to upload the update project version...and I have had the "error message"...with other projects, where I don't use UAC, I don't have problem....do I have upload again the last unilogic version? thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 6, 2017 Report Share Posted December 6, 2017 Hi, Our support gets the error when using the project you've sent, so we will investigate it and you'll get an answer ASAP. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted December 6, 2017 Author Report Share Posted December 6, 2017 Dear Saragani, many thanks... Quote Link to comment Share on other sites More sharing options...
Dz! Posted December 30, 2017 Report Share Posted December 30, 2017 This is typical behavior after update to the latest version with "improved" UAC (v1.21...) It even forced me to update my PLCs to the latest project software via USB flash disk rather than usual Ethernet, because it simply didn't work. Finally I chewed through this. First, you need to disable UAC, then completely remove the old passwords, and finally re-enable UAC and configure it as you wish. And ,voila, everything works as it should. The "the password for Uniapps Administrator bla, bla, bla..." error is gone. What I would like to suggest to the Unitronics team - could you do the old password cleanup step for the users automatically upon they're changing to UAC, or at least warn them they'll be in trouble if they didn't do that before proceeding to UAC world. Quote Link to comment Share on other sites More sharing options...
