darknesspic Posted January 30, 2018 Report Share Posted January 30, 2018 I'm using represent mode of load cell with raw data, please advise me 1. What is the maximum of A2D? 2.Are these raw data same as between difference capacity of load cells(15kg,30kg) Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted January 31, 2018 MVP 2021 Report Share Posted January 31, 2018 If you dig into the specs on the LC1 / LC3 modules, the resolution of the A/D converter is 24 bit or +/- 8,388,608. The span of the module is -20mV to +20mV OR -80mV to +80mV based on software configuration. To answer your second question you need to know the excitation that will be used and the mV/V output of the load cells. But the module itself doesn't change. It has no idea what's connected to it. Joe T. Quote Link to comment Share on other sites More sharing options...
