TODDSTER Posted February 2, 2018 Report Share Posted February 2, 2018 I attached a small portion of the Samba TA22 installation guide. My question is in regard to the battery for the 7-inch model, which I may be using on an upcoming project. The 3.5 and 4.3 inch models indicate the battery is already installed, but the 7 inch does not indicate that it is installed. Does this imply that a battery is included with the unit but I have to install it myself? Or do I have to supply my own battery? I was unable to find the battery number in the installation guide. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 2, 2018 MVP 2021 Report Share Posted February 2, 2018 I haven't used a 7" Samba yet, but I've never seen a Unitronics PLC come with the battery already installed. Quote Link to comment Share on other sites More sharing options...
John_R Posted February 2, 2018 Report Share Posted February 2, 2018 I've used a lot of V280's over the years, they use to come with the battery installed, and not accessible without opening the unit up, but a couple years they changed the case design and included a battery compartment cover with the battery stored in a plastic bag within, and a sticker on the side reminding you to install the battery JohnR Quote Link to comment Share on other sites More sharing options...
