salahedine zidouh Posted March 30, 2018 Report Share Posted March 30, 2018 im struggling now i have a plc unitronics visilogic so i want a timer TON TOFF for 10 s can anyone help me Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted March 30, 2018 MVP 2021 Report Share Posted March 30, 2018 Please look in the Help files, find Timers in the Index and then find Timers (T) in the topic list presented. This explains timers in detail. Visilogic does not have all the timers you may be used to, but the 3 they do cover all operations needed with manipulation around them if necessary. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 31, 2018 MVP 2021 Report Share Posted March 31, 2018 The nice thing about VisiLogic is that Timers work just like regular contacts and coils. You activate a timer just like you activate a coil and you take action with a timer contact, just like you would a bit contact. You can also reset a timer, if needed, with a Reset Timer Coil, just like you would use a Reset Bit Coil. Quote Link to comment Share on other sites More sharing options...
salahedine zidouh Posted April 3, 2018 Author Report Share Posted April 3, 2018 thank you for you'r replies that mean a lot to me thank you for you'r support. Quote Link to comment Share on other sites More sharing options...
