Andreas Posted April 4, 2018 Report Share Posted April 4, 2018 Hi. I got this error when i was trying to save the project. This happends every time i tried to save, even with new projects. Im using UniLogic 1.18.60.0 I know its old, but i there is to many problems with CUP error and HMI overload with the newest update. Anyone that know why this happends? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Andreas Posted April 4, 2018 Author Report Share Posted April 4, 2018 I tried the newest UniLogic 1.23.25, and got the same problem. Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 4, 2018 Report Share Posted April 4, 2018 It looks like some kind of permissions issue. Can you got to %programdata%\Unitronics\UniLogic\logs\ and attach the SolutionHandler log (you should find a file per date. Just peek one that was created when you had the save problem. Alternatively, you can delete all txt file and then start UniLogic, and try to save a project, and after the error happens, attach the created file or files). Quote Link to comment Share on other sites More sharing options...
Andreas Posted April 4, 2018 Author Report Share Posted April 4, 2018 Here is the file. 2018-04-04_SolutionHandler.txt Quote Link to comment Share on other sites More sharing options...
Andreas Posted April 4, 2018 Author Report Share Posted April 4, 2018 Hi. I found where the backup files were saved, i got error code 0x80070718. The problem was that the limit on cash on offline files was full, i increased the limit and everything works Her is an guide how to fix it:https://www.vistax64.com/threads/hard-disk-drive-space-quota.92125/ Thanks!! Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 4, 2018 Report Share Posted April 4, 2018 Yes, it looks from the solution handler log, that the "My Documents" folder is located somewhere on a network drive or network path. (As you've probably seen). I'm glad you were able to sort it out. Quote Link to comment Share on other sites More sharing options...
