Luiz Posted April 12, 2018 Report Share Posted April 12, 2018 I, trying to change baudrate inside the loop program. Is it possible, using COM Init Port ? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 13, 2018 MVP 2021 Report Share Posted April 13, 2018 Yes, that should work. Make sure you use a Positive Transitional to call it. Joe T. Quote Link to comment Share on other sites More sharing options...
Luiz Posted April 27, 2018 Author Report Share Posted April 27, 2018 Thank's for your reply; Regarding the baudrate change, it's working, but I have a question: I'm using V120 22 T1 / OS Version 5.04 (28) / Hardware rev A Is the baudrate 115200 available in this version? The program works, but it's no consistent. The Scan FB doesn't respond sometimes, and I have to reset controller to restablish communications. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 27, 2018 MVP 2021 Report Share Posted April 27, 2018 I don't know full capabilities, but I only ever use 57600 on V120s under serial. Never had troubles. Sometimes you need to ensure Device Manager has the same baud rate in it's settings. This issue seems to be computer specific. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 27, 2018 MVP 2021 Report Share Posted April 27, 2018 Don't run a V120 at 115200 - it doesn't work well. Upgrade to a V130 if you need this baud rate. Joe T. Quote Link to comment Share on other sites More sharing options...
