Paul11 Posted April 17, 2018 Report Share Posted April 17, 2018 Hi, I was a very basic ladder logic question. At the moment I can only force on outputs on from the PLC . My latches do not seem to be working correctly. When I activate the start pushbutton when in online mode the green light output is not activated. I know the output works when forced the output to a 1 the green light turns on. Sorry total new to PLC programming and just trying to get to a handle of it. Any help at all would be great. Thanks, Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 17, 2018 MVP 2021 Report Share Posted April 17, 2018 Do you have power flow all the way to the "Automode" coil when in online mode (i.e. are "Auto_Selector_5", "Stop_2_PB", "Emergency Stop" all closed and "F1_Overload" open)? Is "Start_1_PB closing? Is this in a subroutine? If so, is it being called in the Main Routine? Quote Link to comment Share on other sites More sharing options...
gerard339 Posted April 17, 2018 Report Share Posted April 17, 2018 You need to change the 'automode' which is in parallel with 'start_1_pb' to 'Green Light' Quote Link to comment Share on other sites More sharing options...
Paul11 Posted April 17, 2018 Author Report Share Posted April 17, 2018 1 hour ago, Flex727 said: Do you have power flow all the way to the "Automode" coil when in online mode (i.e. are "Auto_Selector_5", "Stop_2_PB", "Emergency Stop" all closed and "F1_Overload" open)? Is "Start_1_PB closing? Is this in a subroutine? If so, is it being called in the Main Routine? Hi, thanks for your help, I have power all the way to the coil but it's not activating. Should automode that is in parallel with start_pb be an internal bit or a output. I have it as a an global tag. It is the main routine. Again thanks for the help, Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 18, 2018 MVP 2021 Report Share Posted April 18, 2018 What you have should work. Make sure there is only one instance of the "Automode" coil. Quote Link to comment Share on other sites More sharing options...
Paul11 Posted April 18, 2018 Author Report Share Posted April 18, 2018 I should have the green light come on. At line two. It is energised right up to the coil but not the coil itself? Sorry the third line of code a duplicate of line one that was attached in error. Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 18, 2018 Report Share Posted April 18, 2018 Are you sure that the function that has that code is being called? If yes, are you sure the CPU is running? Quote Link to comment Share on other sites More sharing options...
Paul11 Posted April 18, 2018 Author Report Share Posted April 18, 2018 Ya I'm sure they CPU is running. I can force on the all outputs but not through the code. I've even tried th code -Start pusbutton with output green light. The green light is not operating. This is the way iv have entered my outputs? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 18, 2018 MVP 2021 Report Share Posted April 18, 2018 Make sure there is only one instance of the "Green Light" coil. Quote Link to comment Share on other sites More sharing options...
RobertU Posted April 18, 2018 Report Share Posted April 18, 2018 1. Green light is called somewhere else where is turned off 2. Subroutine isn't called 3. Try "download all" and check the result Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 18, 2018 MVP 2021 Report Share Posted April 18, 2018 I'm not into Unistream at all, but is there an "Initialise and Reset" somewhere? If none of the above in Flex and RobertU are true, perhaps it is something that simple...it is stuck on old info somehow. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Cam Posted April 18, 2018 Report Share Posted April 18, 2018 Or if you have made lots of program changes with multiple down loads try downloading a blank program into the unit, reboot it and then put your program back in. Quote Link to comment Share on other sites More sharing options...
