Ayoub Posted April 27, 2018 Report Share Posted April 27, 2018 Hello , I want to add in the alarm history a fault when One power up and power off the PLC . in the power up of the PLC I used the SB2 and it worked. but in the power off I do not know how to do it, I tried to use even SB2 by reversing the contact but it always gives me the startup time and is not the one of the power off. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 27, 2018 MVP 2021 Report Share Posted April 27, 2018 I create my own alarm history rather than use the built-in alarms function, but the technique I use for this could be adapted to your needs. When I create my alarm history, I store the date and time in a vector of MIs using the "RTC To ASCII" function. If you grab the data from that vector in a ladder rung that is executed before the RTC To ASCII function, with SB 2, you will have the last date & time stored just before power loss. Grab the data again with SB 2 just after the function and you'll have the power on date & time. This can be done in 3 consecutive ladder rungs if desired. 1 Quote Link to comment Share on other sites More sharing options...
Ayoub Posted May 2, 2018 Author Report Share Posted May 2, 2018 On 4/27/2018 at 1:49 PM, Flex727 said: Thank you Sir, Please, can you tell me how to recover the value of MIs after having power up the plc, I already tried to do it but I did not arrive there Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted May 2, 2018 MVP 2021 Report Share Posted May 2, 2018 Here is the way I do it. I'm logging the date and time to a data table, but you can do whatever you want with the MI vectors MI 2000 & MI 2005, such as copy the vectors to another location that won't be overwritten in the next ladder rung. 1 Quote Link to comment Share on other sites More sharing options...
