Interroga Posted April 30, 2018 Report Share Posted April 30, 2018 Hi, How to switch language in button names? I'm create application and is necessary change language conform country where for used. Can you help me? I try , but i only can change in configuration program and not dynamic mode , between variable in program. Regards. Quote Link to comment Share on other sites More sharing options...
NoamM Posted April 30, 2018 Report Share Posted April 30, 2018 Hi Interroga, In order to apply language change on HMI elements follow the next steps: #1. Add an HMI element to the HMI screen. For example, I added a "Fixed text" with the value "Hello". #2. In "Solution Explorer" -> "Languages" add an additional language of your choice to the application. For example, I added "Korean". #3. Press on the new language you added and the translation menu will appear: The "Hello" marked in red is the value of the "Fixed text" element when the language of the PLC is Korean. Let's edit the value: #4. Create a change language Action on order to change the PLC language to Korean. For example, I created 2 actions, one for English & one for Korean. When the Action's linked BIT is set (via Ladder, button click...) the PLC language will change accordingly. Example: Now on our "Fixed text" HMI element the text will be "여보세요" and not "Hello" because Korean is the active language, Quote Link to comment Share on other sites More sharing options...
Interroga Posted May 7, 2018 Author Report Share Posted May 7, 2018 Very good explanation. I did not find anything in the help about this doubt. Regards, Mauro Quote Link to comment Share on other sites More sharing options...
Interroga Posted May 9, 2018 Author Report Share Posted May 9, 2018 one suggestion for developer team: i can't edit text in default language , only secondary language. why? it's more easy in the building program edit in block , and not one by one , in each object. Quote Link to comment Share on other sites More sharing options...
